Author Topic: one setting does different things - fix it plz  (Read 1959 times)
xerejo
Hi, about sync with device and album cover
1) in musicbee setting album cover, i check:
  a) cover in file
pic: http://s016.radikal.ru/i335/1510/eb/92507541f0ad.png
2) in device setting about cover i cant use this setting, i can set "in cover" or "place to folver Cover.jpg"...
pic: http://s019.radikal.ru/i605/1510/f2/4ba08aded17a.png
I want to use the settings are the same as in the basic configuration.
Need add point how in basec config OR one point same : "Copy as is".
Sry my bad english.
ask if something is unclear
vy mozhete pisat' po russky, esli eto legche dlya vas, ya perevedu :)
if somebody didn't understand the request then it is: add an option for devices to use the same artwork storage settings as for library files (even if files are converted to another format).
+1
