MusicBrainz provides several types of MBIDs (MusicBrainz Identifiers)
It can be useful to have these available in MusicBee so you can e.g. create shortcuts to the related MusicBrainz website pages.
But to do that, you would need to setup a custom tag for each MBID, and since MusicBee currently has a limited number of 16 custom tags, most of us won't have enough freely available.
To circumvent this problem, I created a Picard script that will populate one custom tag which will contain all available MBIDs.
(that is, all that I am aware of, and find useful)
After that you can create one virtual tag for every MBID you would like to have available in MusicBee.
(assuming you still have enough of those available)
The script to setup in Picard is:
$set(MUSICBRAINZIDS,TRACK_%musicbrainz_trackid%_ART_%musicbrainz_artistid%_REC_%musicbrainz_recordingid%_REL_%musicbrainz_albumid%_RELART_%musicbrainz_albumartistid%_RELGRP_%musicbrainz_releasegroupid%_WORK_%musicbrainz_workid%)
The custom tag to setup in MusicBee is:
identifier: MusicBrainz IDs
tag code: MUSICBRAINZIDS
The virtual tags would be:
MusicBrainz Track Id $Split(<MusicBrainz IDs>,"_",2)
MusicBrainz Artist Id $Split(<MusicBrainz IDs>,"_",4)
MusicBrainz Recording Id $Split(<MusicBrainz IDs>,"_",6)
MusicBrainz Release Id $Split(<MusicBrainz IDs>,"_",8)
MusicBrainz Release Artist Id $Split(<MusicBrainz IDs>,"_",10)
MusicBrainz Release Group Id $Split(<MusicBrainz IDs>,"_",12)
MusicBrainz Work Id $Split(<MusicBrainz IDs>,"_",14)
You can then configure custom weblinks for the track details panel:
https://musicbrainz.org/search *)
https://musicbrainz.org/artist/<MusicBrainz Artist Id>
https://musicbrainz.org/recording/<MusicBrainz Recording Id>
https://musicbrainz.org/release/<MusicBrainz Release Id>
https://musicbrainz.org/artist/<MusicBrainz Release Artist Id>
MusicBrainz Release Group Id https://musicbrainz.org/release-group/<MusicBrainz Release Group Id>
MusicBrainz Work Id
https://musicbrainz.org/work/<MusicBrainz Work Id>
This one is problematic, I couldn't get a direct link working, so this one opens the search page. There you could paste the Track Id. (e.g. copied from the tag editor)
If somebody knows a solution to create a direct link for it, please let me know.
*) edit:
A direct link to the track details seems not possible, but a rather quick alternative to get to the track details is by using the Recording Id shortcut, and then click on any of the numbers in the '#' column on the far left. That will bring the track and all it's details directly in focus.
(and will save you one weblink slot in MusicBee's details panel)
Update: I posted a revised and updated version of this post in Tips & Tricks:
https://getmusicbee.com/forum/index.php?topic=36210.msg198290#msg198290
