Author Topic: mp3tag tags vs musicbee tags  (Read 7429 times)
staggalicous
I have been fixing my tags with a tool called mp3tag for about a month or so now and im "finished" however musicbee does not show the same exact tags as mp3tag does although the majority of the tags are correct to how i changed them.
for example, i have a couple songs where the album art fields do not match up, even though i have tried refreshing the view in mp3tag and creating a new library in musicbee,, and also closing and opening both programs.
I have been editing the tags so that i can use them in both musicbee and upload them to google play music, and mp3tag seemed like the best option.
Does anyone know of what might be causing this problem? Can i change how musicbee reads the tags to look like it does in mp3tag? or if anyone has used mp3tag before can i export the the files for different formats or something to fix it?
can you PM me a link to one or more of the problem files
Also consider that MusicBee won't automatically pick up tag changes made in other programs until you rescan them, as described in this thread:
http://getmusicbee.com/forum/index.php?topic=14637.0
I don't know why the tags wouldn't work in a new library though.
staggalicous
i've tried that and it doesnt change the tags to how they should be
staggalicous
UPDATE: i re uploaded everything to google music and the changes are correct in google music which tells me it has something to do with musicbee
musicbee is doing what i would expect it to in this case.
If you look using the Tag Inspector which is opened from the tag editor, it will show that for the mismatches you actually have 2 sets of album artist tags - one "ALBUMARTIST" and the other "ALBUM ARTIST" which are not consistent with their values.
I would say google is only looking for "ALBUMARTIST". Unfortunately there are several variations for Album Artist between the various players and taggers.
You could either edit the file using MB, change something and then save which should remove the duplicate when saving or edit in Mp3Tag via the right click/Extended Properties menu
Last Edit: December 31, 2014, 10:18:17 AM by Steven
staggalicous
oh ok that makes sense. if i dont reply back for a while you can assume it worked haha. thanks for your help
staggalicous
Ok that worked for everything except these two files. the weird part is that they are showing an album artist however when i go to edit the tags in musicbee the tag editor does not show an album artist. Also if I try to edit it in the library explorer, it just goes back to what it was before when i hit enter. Let me know if you need me to share the files again
Album Artist shows Artist in the main panel if Album Artist is missing.
Also check the tags using the Tag Inspector.
staggalicous
there is album art for both of them. also worth mentioning it is the same album but two different artists. In the tag inspector there is no tag for album artist for either of these
staggalicous
staggalicous
I feel dumb after re-reading this lol
callimi
also musicbee use DATE and note YEAR as tag
  • MB Version: 3.6.8849 P
assume that's supposed to be "also musicbee use DATE and not YEAR as tag"
MB uses DATE and YEAR tags with ID3v2.3 as per the ID3 standard
