Author Topic: Cut the song in edit menù  (Read 2590 times)
Ansem
Hi at all.
In the edit menù->settings it's possibile to set "start/end time".
I would to instead of setting it, to cut the song before/after that time, so that i have a smaller file without the silence parts.
It's this possible?
MusicBee isn't really designed for permanently editing files.
Try a program like MP3DirectCut. It can edit files without re-encoding them, so you don't get any additional quality loss.
Ansem
Yeah i know, for that i suggest a very simple thing, just like cut the song, no more else :)
