Author Topic: Synchronized folder  (Read 2413 times)
risko
Hi, I would like to synchonize music folders. I have default music folder wich I want to sync with my music backup on external hdd and on 2nd PC. Could you do this feature please?
there is a backup library command (File/Backup Library) that copies new files and updates files with more recent versions (as long as you dont have 'dont update timestamp when modifying files' ticked in the tag preferences).
However it currently doesnt delete or rename files on the target drive (to keep it simple) so if you do a lot of re-organisation it might not be suitable.
