Author Topic: Adding text to a subheader  (Read 1377 times)
lbelloq
Hi all, I got a question.
First of all, please look at this picture (it's my MusicBee current setup):
I've orderred the albums by album name and set the disc number as subheader.
What I'd like to do is, in the disc number subheader (the parts circled in red) have an additional text, for example, instead of just the disc number, something like "Disc #" and the disc number.
Is there any way to do this?
Thanks in advance.
You can set up a virtual.tag for that.  Under preferences > Tags (1) > define new tags, enter something like "Disc #<Disc#>".  Give the tag a name and make that your subheader.
lbelloq
Worked like a charm. I had to remove the "#" from the text because it doesn't parse the disc number correctly. Thank you.
