How do I move my playlists from MB on my PC, to my Galaxy S5 phone. All of my music has been cleanly added to my phone's Music library (original source files from iTunes, ripped from CD's, so all music is m4a files). Both the Samsung "onboard" player and PowerAmp recognize and play all 2,550 songs and also list them in the properly tagged categories (song titles, albums, and artists...since I have not modified any tags from the original CD info, when ripped in iTunes). I have spent many hours experimenting with forum advice but evidently it is all over my head, since I am a total novice to all of the "foreign to me" terminology explained. I have used the right click option of "save as external playlist", but can't get any transfer to take place (been using the Windows Explorer navigation panels, and using both an external hard drive and then a micro SD card to try to get them transferred to my phone, with absolutely no luck. Also please explain the difference between save as library playlist versus exported playlist. I am afraid to click on library playlist, for fear I may do something that I don't know how to repair, if the result is unexpected. I can't seem to find any "dictionary" in MB that defines many of the terms, such as "Library Playlist". Should I save every playlist as a Library Playlist, as the most sensible thing to do. I guess I don't understand the nuance of differences, as a novice user, since the playlists are already there in the MB explorer window.
I need an easy to understand tutorial, explaining what specific steps should be taken to move my static playlists onto the phone so the two player programs can utilize them? Very frustrating to get this far and not be able to take the last step to put MB into action, since I spent over 100 hours cleaning up a totally disorganized music library which somehow ended up with over 6,000 music files (duplicates of the base library which should have been around 2500 songs). After removing all duplicates and getting the song tags back to their original file names, I then added all 2,550 songs back into specific playlists (a second time....Whew, what a pain). So now, my core library on the PC and in MB, along with the new clean playlists, are ready for the last step.....getting the playlists onto my S5 phone. Your help is much appreciated. A step by step action list, starting with where the Playlists reside in the MB left hand explorer window, and then transferring them to a flash drive or my Samsung S5 phone, connected to my PC through a USB port, would be most helpful. Using Windows 8.1. Music files on the phone are in a file under SD Card..."Music". Thanks for your unselfish assistance.
