hey, so i installed it, and tested it !
touch works just fine with this version in the artist artwork view!
BUT, if the artist has many albums, and they dont fit in the screen, you have to press the "Arrows".. you cant scroll left-right..
also, if the Screen is too narrow (etc its on Portrait mode), and i open up a menu, that dosent fit in the screen, then , even if i move it, i cant get it to show the rest of the options (Apply, save, etc).. i think it needs one vertical scrroll bar??
anyway ! thanks again !
