Author Topic: Help!  (Read 3980 times)
dmarklinger
I am getting this error message on EVERY music file that I have? The library is displayed, but when I click on a file, I get an error message like this...HELP!:
12-Aug-2015 06:50:37 - 6.1.7601.65536 - 2.4.5404.16303 - url: E:\Cliff Richard - From A Distance.mp3
System.TypeInitializationException: The type initializer for '#=q53jis_rR7AJRlXRAGb8MOA==' threw an exception. ---> System.ApplicationException: Unable to load 'C:\Program Files (x86)\MusicBee\MusicBeeBass.dll'
   at #=qKxLTdg1nSVDdZclpPVxWPY6uYjJY5nF_QEoCuW$WlT4=.#=qdfkoZH8SoMoNxDLNUJkcpO5RVFY1LaUebyVza3jJesU=(String #=qN4qnYVr3fxdhzs4ng40PeA==)
   at #=qNtm5iJOaUzcax$YlkXYhZQ==.#=q53jis_rR7AJRlXRAGb8MOA==..cctor()
   at #=qNtm5iJOaUzcax$YlkXYhZQ==.#=q53jis_rR7AJRlXRAGb8MOA==.#=q_rmAEOUwQnkvu0ZnexlKbnzs7Ub80yp3bEh7B3nBbzsUmVsqtFg96lMT3oAia8hf(Int32 #=qYYZAS1EILWJnL2Y_unrMaw==)
   at #=qIoOVuKwlbh5ChfLnyUVKto6srlYsDygM2DxGaz8hllg=.#=qy0u1hihKW6Bv3HPjyuDynw==.#=qH5d9DzTTfRphuZvhuUSMEg==(Boolean #=qxygqzTRq51jVHBK8bDRNdg==)
   at #=qIoOVuKwlbh5ChfLnyUVKto6srlYsDygM2DxGaz8hllg=.#=qy0u1hihKW6Bv3HPjyuDynw==.#=q1cVc2up9uM_iBfhZ1hWdQQ==()
   at #=qIoOVuKwlbh5ChfLnyUVKto6srlYsDygM2DxGaz8hllg=.#=q1q9qc6iI9fpge7eixDkl0Q==(Object #=qPcr3jVOVxSWJwl4NjeM4$Q==)
Looks like something is going on with MusicBeeBass.dll.  Either your AV program is blocking it, or it is corrupt.  Try using the latest 2.5 patch (see my sig) which will overwrite the dll.
dmarklinger
 :D
THANKS...that was it! APPRECIATED! I am running AVAST Free AV, cuurent version, and that was what was blocking that .dll
MuiscBee is GREAT, by the way ~ head and shoulders above ANY other music media software ANYWHERE....NO question!
And I appreciate this! Thank you...............
You're welcome.  Glad to hear it worked out.
dmarklinger
It keeps happening...must be some utility or the AV doing this?
The patch DOES repair it though....
I run CCLEANER GLARY SPYBOT SUPERSPYWARE MALWAREBYTES all about every 2 weeks
Avast Antivirus and MSSE are running at all times.
Windows 7 HOME x64 desktop pc
ALL software is current....
Avast is notorious for creating problems with MusicBee.
Do a google search for the 'Avast NG' and 'Avast DeepScreen' features, and see if you can make it work changing those settings for MusicBee.
(and when possible report back to help others)
Skoop
Don't do this.  You only need one.  Get rid of Avast.  Uninstall it and just go with MSSE.
Agreed.  Regardless of MusicBee, two security programs will just get in a tug of war and drain your resources
