Author Topic: Database Question  (Read 4714 times)
wrwetzel
I would like to access the MusicBee library database file, MusicBeeLibrary.mbl, outside the scope of the MusicBee application to look at some of the statistics of my library. Among other things I would like to find the most common titles, artists, etc., look for titles, artists, albums, etc., with spelling errors, and more.
Is the database file in a form that is supported by one of the common database applications, e.g. Sqlite, MySql, Postgress, etc.? A quick look did not reveal anything distinctive to me and I was unable to view it with Sqlite tools.
Thanks,
Bill
The Additional Tagging & Reporting tools plugin should help you there.  Messing with the database directly is a bad idea.
http://musicbee.wikia.com/wiki/Additional_Tagging_and_Reporting_Tools
wrwetzel
Should not be a problem as long as I open it read-only, which is all I need as I have no desire to change it.
Bill
I really think the plugin is your best bet; it has very comprehensive tools and good support.  Steven has not offered any suggestions on accessing the database in the past.
I'd suggest copying the .mbl to another directory before you open it.  That way you can copy it back should something go wrong.  Once it's gone, it's gone.
i confirm the darabase is only intended to be accessible via exporting an iTunes xml file, the API or the reporting tools plugin
wrwetzel
Thanks to all for your comments. I have looked at the Additional Tagging Tools plugin and it appears that it will satisfy my needs. My original question still remains unanswered, however:
Thanks,
Bill
