Author Topic: Not saving embedded artwork  (Read 8362 times)
Sofocl
Flac files.
http://www.unibytes.com/uqwta.WoHCILqw-Us4P3UgBB
libFLAC.dll 152 KB (155,648 bytes) September 16, 2007, 14:39:52
Sorry for my bad English.
looks like i had some code commented out - it must have been when i was debugging something.
Its back now and artwork should save normally now
http://musicbee.niblseed.com/V2_5/MusicBee_Exe_Patched.zip
Sofocl
It works, thank you!
What about the second file? Cover is not really removed from the file. Problem remains. If the file just to open in AIMP and click save Cover removed.
i dont see any picture in the 2nd file. Are you sure the application you viewed with wasnt showing the cover.jpg file?
Sofocl
Pay attention to the size of the second file, it is more precisely the size of the cover.
Last Edit: August 01, 2015, 08:47:22 PM by Sofocl
mtone
Sofocl, this is an unrelated issue. It is common with FLAC files that the disk space allocated (padding) for prior artwork is not reclaimed after deleting the artwork. I'm not sure if there's a way to force MusicBee to rewrite the file, but solutions include:
 - Re-encode the flac over itself
 - Use an external utility, metaflac, to do so. Either one-by-one or a batch file ( http://forums.mp3tag.de/index.php?showtopic=10066 )
Sofocl
mtone You're right, foobar2000, MediaMonkey have the same behavior. But Aimp is somehow implemented, then in MB can be done. But it is need to Wishlist.
