Author Topic: Edit window will not pop-up  (Read 2851 times)
icculus71
Hoping for a little help:
rt.click - edit & shift+enter will not bring up the tag editor?
the highlighted track turns from blue to grey and nothing else happens...?
thanks
Hi, welcome to the forum!
Do you have or have you used multiple monitors at any point?  I know there's been an issue in the past of a pop-up window trying to open in a monitor that's no longer there.
I think upgrading to the latest update will solve that problem: http://musicbee.wikia.com/wiki/Latest_Update
Last Edit: July 24, 2015, 04:02:30 PM by psychoadept
Latest patches (3.5/3.6)
icculus71
i almost always use multiple monitors...and different ones depending on where I am working.
I am going to attempt an edit, while working with the external monitor disconnected.
icculus71
BRILLIANT.
disconnected the external monitor and it popped right up...
would of never found that...Thanks psychoadept!
You're welcome!
Though I gave you the wrong link for the latest update.  Not sure how that happened, but I've fixed it.
