currently testing (comparative listening) driving a high quality external USB DAC from MB, toward a high quality HiFi installation. Using WASAPI because DAC does not support ASIO (according to manufacturer for well considered reasons, sic).
Question: does MB support WASAPI in event mode (aka async, not push, not sync, not adaptive)?
Background: current set-up works fine (functionally), but does NOT provide the same quality sound as can be achieved with other players that do clearly support async (event) mode. Those other players clearly show the WASAPI capable USB devices twice, one in push and once in event mode.
MB only shows them once, and does not indicate mode. And from comparative listening it seems that MB uses push (or adaptive) mode. That implies that USB transfer is regulated by the (dismal) PC clock, rather then the optimized clock from the USB DAC. And that difference can (very clearly) be heard on high level HiFi installation. As a true audiophile, that actually eliminates MB as a viable player.
However, should it be possible to engage event mode, due to its superior functionality on many other aspects, MB would be the go-to player if it provides async mode. So if the answer is currently negative, I will put this in as a request for evolution.
Thanks and kind regards.
Jan
