Hi
I've never had this at the end, but some other www's (I don't remember which ones) somewhere in the middle of the lyrics. So probably, you're going to open Pandora's box, if you start removing some text
On the other hand, maybe it would be a good thing, if I could define some replacement text for my own and/or MB had some predefined ones:
- Some of the lyrics have HTML code in it, i.e. & " and language specific ones like ä (I'd prefer to see and store &, ", ä and so on)
- Some other lyrics show stupid code (I suppose UNICODE) instead of letters above ASCII code 128 (maybe more important, if you have non English songs in your database...)
This way I could also replace some URLs by nothing (and remove automatically CR/LF, if it's at the end of the whole text)...
Just an idea, I'm not sure, if that would be enough for Maleko12.
Regards
