Author Topic: go to next higher or lower entry in column browser on tag change  (Read 3506 times)
I know this has come up a few times recently, but I'm not having any luck finding the older posts.  If there's already a solution in the works, ignore me.  Or point me to the right post.  :)
It really is annoying when you're trying to edit some tags and every time you make a change that eliminates a column browser entry, it sends you to the top.  I think it would be much more user-friendly to go to the next entry in the list.  I think going down the list would make more sense than going up, since people are more likely to be making their way consecutively down the list making changes, but that's a relatively minor detail.
(Current example: I have some genres that are being read as strings and in order to fix them, I find the entries in the column browser, then go in and quickly resave each track in the main panel.  I'm just working my way steadily down, and don't want to go back to the top.)
Edit: Tangent, but I managed to solve this particular problem quickly using the reencode tag command from Additional Tagging & Reporting Tools.  I think the adjustment to column browser behavior would still be helpful, though.
Last Edit: June 23, 2015, 04:02:02 AM by psychoadept
+1
Pingaware
+1
This comes up very frequently, and while it's not something that bothers me, I can well understand that it's not quite intuitive behaviour.
udubber83
"Edit: Tangent, but I managed to solve this particular problem quickly using the reencode tag command from Additional Tagging & Reporting Tools.  I think the adjustment to column browser behavior would still be helpful, though."
can you explain how this was done?   This problem is really annoying to me as well.  thanks.
You need this plugin: http://musicbee.wikia.com/wiki/Additional_Tagging_and_Reporting_Tools
Then go to Tools > Tagging Tools > Reencode tag...  Tell it what tag you want to reencode, without changing any other settings.
udubber83
thanks for the reply. I installed the plugin but not really understanding how it works.  do i just hilight the song I want to retag, then go to tools>tagging tools >reencode tag and then click 'proceed'?    Then am I able to retag a song artist name w/o losing my spot in the artist column?  Right now it isn't working.
Yeah, highlight the tracks you want to process first.  If that doesn't help, you'll need to provide a screenshot of what you're doing that's not working.
