Author Topic: help!!  (Read 1515 times)
NIKITASGOLD
keep getting this error box
please help i need my music on my iphone will have to go back to MediaMonkey if this keeps happening
MusicBee v2.4.5404.16303 (Win6.1), 20 Jun 2015 11:38:
System.InvalidCastException: Unable to cast COM object of type 'System.__ComObject' to interface type 'iTunesLib.IITIPodSource'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{CF4D8ACE-1720-4FB9-B0AE-9877249E89B0}' failed due to the following error: The application called an interface that was marshalled for a different thread. (Exception from HRESULT: 0x8001010E (RPC_E_WRONG_THREAD)).
   at System.StubHelpers.StubHelpers.GetCOMIPFromRCW(Object objSrc, IntPtr pCPCMD, IntPtr& ppTarget, Boolean& pfNeedsRelease)
   at iTunesLib.IITIPodSource.EjectIPod()
   at MusicBeePlugin.ITunes.Close()
   at MusicBeePlugin.Plugin.Eject()
   at MusicBeePlugin.Plugin.turnOnEventHandler(Object sender, EventArgs e)
   at #=qkqD_24K_jqNNsY4ytXfL8gdU4AeJG50yEcwQQ82gVnW0tjNMKqAPXQTcHSTEGGUx.#=q_BllApB1jquyAgblsRWAGQ==(Object #=qHIgSGJS$_ycrUlpxd6kRrg==, EventArgs #=qdjAGRgNuykZe8nBxToZIxg==)
Pingaware
MB doesn't natively support syncing to iPhones or iPods due to restrictions from Apple. If it was working before, you're just lucky.
NIKITASGOLD
hi yes I know but installed the plugin that makes it work and this keeps showing i click on ipod turn on and itunes appears but when i try to sync i get this??
oh well going back to media monkey it was worth a go but did not work its just that itunes crashes all the time media monkey gets alot of "not responding" and errors with missing scripts tried uninstalling and re-installing both to no avail thought i would give this a try but not really working will have to find another alternative!!
You'll need to report this bug in the plugin's thread.  It will be in the Plugins forum.
