Hey, hopefully this is the right place to post this.
I used the search function, and there seems to be a problem with scrolling with some touchpads, but I wanted to make a more specific bug report as maybe that would help sorting it out.
So, I'm using MusicBee 2.5.5524 on Windows 7 with a Dell Touchpad. With my USB-Mouse I am able to scroll whereever the cursor hovers in the application. When I use my touchpad, it uses 2-finger gestures for scrolling. With the touchpad, scrolling is only possible after focusing the element with a click, and not possible at all in the library explorer. When scrolling with the touchpad, it scrolls whereever I clicked last, so when I hover the current playlist with my touchpad but clicked the main panel before, I will still scroll in the main panel. Also, when scrolling with the touchpad in anything but the cover grid, the scrollbar doesn't get updated until I click there another time. That means that I could scroll from the top to the bottom and the scrollbar would stay at the same place.
Thanks for helping!
