Author Topic: Hotkey to go Back/Forward In Tagging Popup Window?  (Read 3072 times)
jamburglar
Is there a hotkey for the left/right arrow keys (pictured on the bottom left) to navigate back/forward when tagging multiple files?
Screenshot: http://i.imgur.com/fsyJTPd.png
It looks like there is a hotkey available for this, but it's unassigned by default.
Edit > Preferences > Hotkeys > Edit: Save/Go to Next
I do not see one to go save and go back.
jamburglar
Strange... I'm not seeing that. Using version 2.4.5404.
Screenshot: http://i.imgur.com/zQZV5Vw.png
Pingaware
Probably means it's an update in the latest version. See phred's signature for details.
Version 2.5.5593
jamburglar
Thanks. I downloaded the latest version but the hotkey only seems to work once. After that, it doesn't seem to trigger an action.
Have you tried a restart of MB?
If so, and the problem persists, you should probably post a bug report.  Be sure to list your version and a step-by-step of what you are doing.  I guess the main question is if that's the intended behavior, although it would seem that it should save and advance with each invoke of the hotkey.
Steven isn't very available on the forums these days, due to his working on the framework for version 3, but it may catch his eye and offer some advice.
That's probably because it loses focus to a selected tag box afterwards. Ticking global setting will make it continue to work.
