Author Topic: Can I get Soundcloud Back?  (Read 9122 times)
Jonnydark
Hi MB Hive Mind
I loved having Soundcloud in music bee to search music while working. Now it doesn't work. Is it gone for good?
Thank you!
Jonathan
I don't know that SoundCloud ever left.  It's located under Services in the left-hand panel.
Download the latest MusicBee v3.5 beta patch from here.
Check out the MusicBee Wiki.
How to post screenshots is here
browm77
Quick follow-up:  Was a soundcloud extension included with a new version of MusicBee? Or is this a plugin that one would need to install.  I'm currently using 2.3.5188.
I never use the services tab, but I would like to start incorporating SoundCloud into my MusicBee experience.
It is a newer feature.  You will need to upgrade to 2.4 from the Downloads page, and then you may still need to update to the latest version, which is linked from phred's signature.
Jonnydark
Yay! I updated and it works now!
Thank you! working will be so much more fun again.
Thank you lovely people.
Jonathan
browm77
Ok, thanks.  I downloaded the final version of 2.4.  Do I need a SoundCloud account first for the SoundCloud feature to work?  Right now it's empty and I can't use it to find music.
On a related note, is there anyway to customize the services dropdown menu?  Once I right click on Upcoming Concerts for instance, there is an option to remove, but it is faded out and unclickable.  I think Upcoming Concerts is a nice feature.  Unfortunately, I live in the middle of nowhere right now. :/
No need for a SoundCloud account.  Enter your search criteria in the search box located in the upper right area of the main panel.
Not at the present time.  If this is important to you, I suggest a search through the Wishlist sub-forum and giving a +1 to the request.  I'm pretty sure you'll find at least one request there, as this has come up before.
browm77
Ok. Thanks.  I had to download 2.5 for this to work.  I guess this feature doesn't work quite as I imagined it might.  Is there a way to create a playlist from songs on SoundCloud on MusicBee?
As far as I'm aware, not directly.  But you -can- download some of the SoundCloud tracks.  Look at the screen shot above and note the fifth track from the top (#34.) Note the little down arrow in the SoundCloud icon.  Right-click and select one of the two download options.  And then you can create your playlist.  Yes, I know --- if the track you want can't be downloaded, you can't put it in a playllst.
browm77
Thanks.  I knew it was coming soon, but I guess I forgot about it and didn't even notice until you pointed it out.
I can add regular soundcloud tracks to a playlist just fine.  They probably wouldn't sync if they hadn't been downloaded, but they will show up in the playlist.  Maybe it's because I added them to my library first?
[Edit] No, I can even add them directly from the soundcloud search.  I think they'd have to be in your library to be selected for auto-playlists, though.
OliWally
I have the SoundCloud button but when I do a search nothing happens. Are there other settings that I need to fix up before it works?
No. Check if you can access the site using Internet Explorer.
you need to use v2.5 available from the first forum topic as soundcloud made some changes
