Author Topic: interesting sync percentage (>100.000%)  (Read 4834 times)
find-the-pig
Hey Guys.
MusicBee is syncing my Files to my OnePlus One porperly but sometimes the progress info shows funny values^^
a screenshot here:
I don't know, how to reporduce this. Half of the time I get normal values..
settings: http://pastebin.com/2F4mG5K8#
does someone know the reason for this?
greetz find-the-pig
What version of MB are you using?  (Help > About)
I often see 104% or something like that, but never what you have.  And mine is usually with a virtual device, which may make a difference.
find-the-pig
latest beta: 2.5.5516
I see values like 104% as often as 100,000%.
I'd say something link this:
regulary 100% - half of the time
100 - 150% - 2/10 of the time
>150% up to 1,000,000% - 3/10 of the time
greetz find-the-pig
ihavnoclue
is it the case for both of you that "," are used for decimal points?
TuRDMaN
I've never seen a sync percentage lower than 100%. In fact, it starts at 100%, and goes into the hundreds of thousands. I think it has something to do with syncing using the option "fill device with random selection".
