Author Topic: can you use an album artwork only layout?  (Read 1566 times)
localnoise
I want to make it so that the only think on the screen, instead of a list of albums, is tiles of album artwork instead that I can push, is there a way to do this? like itunes
Edit > Preferences > Layout
I'm going from memory, but I think there you should be able to disable any of the extra screen elements you don't want.
Then in the main view change the view to "Artwork" to show album covers. You may also need to deselect some of the other elements in the View menu (like Column Browser).
If no one else responds I'll clarify later when I'm at home.
My bad. The Layout preferences don't provide for hiding the side panels.
Instead, use the toolbar button to the left of the search field - it's a little square divided into four areas - to hide the left and right Sidebars and the Column Browser, and set the view to Artwork.
