Author Topic: Disc Number under Album listing  (Read 5425 times)
RealPetChicken
Anyway to add the disc number under the album listing, the picture below explains it better. When you have an album with a bunch of discs, it becomes confusing. Thanks.
  • MB Version: 3.6.9255 P
right-click on the open album panel and select 'Configure Layout'
you can add the sub-grouping header there
a guide to using the sub-grouping header is available here
RealPetChicken
Thank you, i am trying to add the words Disc # before it, the link you posted shows how to do it, but i just can't seem to get it to work.
if you just want to just add "Disc #" to multi-disc albums, make a virtual tag with this template
$If(<Disc Count>>1,"Disc "<Disc#>,)
and use that virtual tag as your sub-grouping header
RealPetChicken
Man, you are the best, thank you, works great.
snow344
Sorry for the necrobump, but a better code is:
$If(<Disc Count>>0,"Disc "<Disc#>,)
That would add the disc number to all albums with a disc number, not just multi-disc albums.
