I use WMA format for my music files. I have noticed in Tag Inspector that "DISC COUNT" uses the "foobar2000/TOTALDISCS" Tag Code, which appears to be the only foobar2000 tag code used in my metadata.
I wonder whether "foobar2000/TOTALDISCS" is the tag code which MusicBee uses naturally for this parameter, or is it somehow a left over from the fact that I used foobar2000 (briefly) before I found the MusicBee path to righteousness?
If it is indeed a left over, what tag code would MusicBee use for this parameter when free of outside influence .....
Many thanks
