I'm not sure why you would need to do anything on the second PC except create its own library and point it to the folder with your organised music in it.
By default MusicBee won't apply naming rules etc. to new files, but you will probably need to change your Library settings to add new files directly to the Library instead of the Inbox.
Simple - sometimes I'm on 1st other times on 2nd computer, adding new music files to the library.
If there is any "supported" or "the right way" to use MusicBee on different computers interchangeably, it would be fantastic to know.
@redwing:
Yes, could work, but when running from two computers at the same time... some file sharing issues could occur.
I have tried (semi-manually) syncing the database or even the MusicBee folder between computers, but while it looks to be ok in most regards, I really would not want to mess up the library - which is very possible in many ways, with automatic rules for example...
One question though, if I may:
If I set MB to monitor 2 folders for new files:
1. "regular" inbox destination
2. actual already sorted "main library" folder
Will MB take files from the already sorted "library" folder and just leave them, or put them in the same folder again, with no problem?
For example, running some rules again could mess things up.
Thanks for your responses!
If I understand correctly, right now, there actually is no "clean" solution for this.
Well, MusicBee still has every feature and function one could wish for!
Bee well.
