The "Playlist Manager" node can be used now. Keep in mind it is only visible for configurations where the left sidebar is hidden. However I will make a further change so it can be added as a tab even when the default configuration has the left sidebar not hidden.
Great! I've been playing around with it, pretty good so far.
Do you mean it will later be added as an 'available element' to the layout configuration? That would make sense.
A bug report - for me the 'playlist manager' node in the left sidebar doesn't always appear, I'm not sure exactly what's causing the issue, either restarting the app or enabling/disabling the left panel can sometimes fix it. I do have multiple tabs if that makes any difference.
By the way, I couldn't get my portable device to appear in the playlist manager, is it possible to add that functionality?
Usually when I'm editing/creating playlists I'm also syncing my phone/tablet at the same time, so that would be helpful.
Another request - could there be an option to disable 'audiobooks' and 'inbox'? Personally I never use those nodes.
Edit: Something I just did broke MusicBee, I don't know if it's directly related to the playlist manager. At the time I was trying to get the node to display as I mentioned in the previous paragraph. When I start up the app I get this error message and can't proceed further:
MusicBee v3.0.5762.40557 (Win10.0), 12 Oct 2015 12:08:
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at MusicBee.MusicBeeMain..ctor()
at MusicBee.MusicBeeApplication.#=qV4md_KlOTQvZ7j$Jga71Jg==(String[] #=qYjXlvPLalXY_YJVTpliTPg==)
PS: I'll send you my settings file, maybe that will help.
