Author Topic: GUI changes for v3.0  (Read 1154282 times)
The latest release is always here:  http://getmusicbee.com/download.html
But there are often more recent patches.  They can be found from my sig, or here: http://musicbee.niblseed.com/V3_0/MusicBee3_Patched.zip
cartman005
Was it intentional to change the search box behavior for v3.0 so that when CTRL+F is pressed, the existing search string is no longer highlighted? I have been looking but don't see any mention of it. This keeps messing me up when doing multiple searches in a row. Most other applications, like Windows Explorer, use the old behavior.
its working fine for me. Could you post a screenshot of the dialog window
I created a new thread in the bug section with screenshots.
brx
I have found this bug. (I think this action was working in previous versions of MB).
1)Press CTRL+A (select all)
2)Now exclude some albums by pressing CTRL and click on the album art, but nothing happens.
MB v3.0.5971
http://makeagif.com/JsqLsP
thats addressed for the next patch version
Tygr
Just tried the 3.0 Version.  I like the new look.  Thanks for the work on MusicBee!
fkm
I have quite a few playlists as tabs but as the list gets longer and longer, I still use the sidebar or playlist manager for accessing the rest of my playlists. It got me wondering why there's no way to rearrange the order of playlists either in the sidebar or the playlist manager.
Something I also think would be great is an option to create a blank space to go between playlists (or certainly between smart and normal playlists etc). Visually, it's a small touch but makes for faster and easier recognition of what playlist you want to use.
this and also a couple of other bugs fixed:
unzip into the folder MB is installed
yes its a resizing issue with windows graphics. I have put in some handling for that
This issue wasn't completely fixed. It still happens when the skin has no custom "NoArtwork" image override.
See the right side & bottom line of the following image with Azure (Pastels) skin.
thats fixed now:
Saving with tag editor flickers album cover of the album in the main panel on album view. This doesn't happen on any other views including artist view.
its non-trivial to change that so i wont make any change for the v3 patch
actually there was a simple solution so its done now
Last Edit: May 18, 2016, 10:01:48 PM by Steven
Thanks, that fixed it!
Xenatier
I've been using an older version of 3.0 and just now updated to the final. It seems like you can't have the column browser visible in certain tabs like you use to, now it can only be open or closed in all of them. Am i just being an idiot or can you not do that anymore?
