I created a playlist with the Duplicates Manager tool (thanks for the playlist naming prompt!). When I selected one file and use it to replace another, the original file is not removed from the playlist, it just floats to the top with a (!).
I just noticed that sometimes when I use "Send To > Use File to Replace Another File" I get a confirmation dialog, and sometimes I don't. I can't tell if there's any pattern to it. Happens even within the same album.
On v2.5, if you switch from album view to track details view, thumbnail browser immediately displays track count instead of album count. But v3 requires reopening of thumbnail browser to change the displayed count.
also the mini player that could look a lot better with some better info like total album size, total album time, track rating etc.musicbee and dopamine miniplayer.
Quote from: psychoadept on February 15, 2016, 03:51:34 AMI created a playlist with the Duplicates Manager tool (thanks for the playlist naming prompt!). When I selected one file and use it to replace another, the original file is not removed from the playlist, it just floats to the top with a (!).I am not able to reproduce this. For me the replaced file is renamed to the new filename so I end up with two files in the playlist with the same name. Is it something you can reproduce or perhaps you were doing other things as the same time and maybe externally deleted the file?
Not sure if this is something on my end, but it happens with every skin. When viewing the compactplayer with TM, the panel is compressed severely to the left side and the rest of the panel is completely transparent.
It happens very consistently, even for tracks delete in other panels. Here's a GIF: http://imgur.com/xBE6P6b
Quote from: psychoadept on February 16, 2016, 09:09:56 PMIt happens very consistently, even for tracks delete in other panels. Here's a GIF: http://imgur.com/xBE6P6byes i can reproduce using the "Replace Selected File" command (but not with the other one). I should be able to address it for the next update
Also, not sure if intentional but to change compactplayer settings, you must navigate to main player>edit>pref>layout2>config. This seems a long way from the compactplayer, It wouldbe nice to access settings from within the player itself as with v2.5.
Just a suggestion. How about displaying "narrow scrollbar", "show icon" for tabs, "show open/close button" on status bar options at the left side of panel layout editor? I feel they got buried deep and many wouldn't even know their existence.
