Author Topic: GUI changes for v3.0  (Read 1233280 times)
Boile
Hi Steven,
In the Tracks view, the Album - track# sorting, does not work!
Thanks
3.4.7586
if that were true dont you think someone would have reported that by now?
please post a screenshot of your main panel and also of the Sort/Grouping preferences window
Boile
Hi!
What should I set in Sort/Grouping ?
I have set Album/Track#
Thanks
3.4.7586
theta_wave
Steven previously resolved the left-sidebar glitch issue when navigating to the now playing or music explorer tabs: http://getmusicbee.com/forum/index.php?topic=18143.msg109164#msg109164
For the most part, the fix works well.  However, sometimes now I find the library explorer (here, a non-functioning mood column) cutting the navigator in half on the left-side when navigating to the aforementioned tabs:
https://youtu.be/pajo8GTq3Eo
It is just a minor glitch as seen in the video.  Navigating back to a playlist tab reverts it back to normal.
can you PM me a link to your settings file (help/ support/ view settings)
sleepless
For me, the image rotation/selecting images does not work for Track Information in the Now Playing panel. It functions fine in other areas, but not with Now Playing. In the screenshot you can see that image 4 is selected, but only image 1 is displayed and no rotation occurs:
Oddly, if I double-click on the image, image 4 is displayed in the pop-up window:
This happens with all artists/albums. I know it was working fine, but not for at least 2 weeks now.
I would probably need your settings file (help/ support/ view settings)
theta_wave
Thanks.  5968 works great now.   When switching to Now Playing or Music Explorer tabs, the Artist tab on the left panel is temporarily removed without any incident.
Boile
Sorry Steven,
it was my fault , i  had had "the following fields define an album:" ticked
Thanks
3.4.7586
