Click on a track in the main panel and then click on a library filter. You will see focus has not moved to Music node, and if you keep clicking on other filters, random tracks in the main panel get highlighted instead of Music node in the left navigator. v2.5 is working properly.
the focus issue is addressed for the next update. The highlighted node in the main panel should be the last active one for the filter in the current musicbee session
Looks like "selected track" issue is more complicated than I thought, and I am now no longer sure what's the correct behavior.
1. For non-filter node like inbox or playlists:
Click on a track in the main panel and then click on the same node (or a node that includes the selected track) in the left navigator. Currently the track gets unselected in the main panel and track info, lyrics, etc. panels show "No selected track" message. But with v2.5 it remained selected under lowlight selector in the main panel and other panels.
2. library filters:
Click on a track in the main panel and then click on the same library filter node (or a filter node that includes the selected track) in the left navigator. Currently the track gets unselected in the main panel, but remains selected in track info, lyrics, etc. panels (this is a bug). But if you switch to playing track and then return to selected track, then those track info etc panels correctly show "No selected track" message. With v2.5 all panels show no track is selected.
3. Another selected track bug:
Click on a track in the main panel and then click on any other node in the left navigator. Likewise #2, the track gets unselected in the main panel, but remains selected in track info, lyrics, etc. panels (this is a bug). But if you switch to playing track and then return to selected track, then those track info etc panels correctly show "No selected track" message.
My opinion is that if selected track is included in a newly selected node, then the selected track should remain. Especially I don't get why the track gets unselected when you click on the same node again. Also make filter nodes and non-filter nodes behave consistently.
