1. the text color is pink... how can i change that?
2. the main bar, how can i change it to that bar? centered text icons... etc...
Welcome!
1. Well, I can't answer for endeavour1934, but he made a magenta version for MB v2.4. Maybe, he'll make one for v3.0.
But, if you can't wait, you'll have to edit the skin file (if it's a "bitmap" skin, you'll have to ask him for the source)
Here the values:
Win 8.0: magenta = 193,0,79
Win 8.1: magenta = 194,0,71
If you're using the hidden win10 dark theme:
magenta = 195,0,82 // background = 31,31,31 // White = 255,255,255 // Light grey = 165,165,165 (what I'm using in my screenshot)
2. Not sure what you mean.
Tabs : I explained everything
here. + preferences->layout (1)->header bar section->tabs bar: show below caption bar
Icons: check
hereCentered text: not doable.
