Author Topic: GUI changes for v3.0  (Read 1284943 times)
Pulled up Tracks view and got this error message. Also occurs when switching to Artist view.
can you send me a link to your settings file (help/ support/ view settings)
edit:
actually i suspect you have only posted part of the error and its the same as someone elses. Its probably fixed for the next update
Last Edit: March 09, 2016, 09:55:13 PM by Steven
"Paste artist picture" is not working in music explorer
Latest patches (3.5/3.6)
i recall someone requested that years in the A-Z be supported for vertical orientation. Thats done for the next update
Edit: Noticed a bug, the link to the profile page only works consistently when in the Album & Stats tab.
thats fixed for the next update although i will probably add a dedicated tab for it
- fixes and changes for the items stated as fixed above
ankor
edit:
I also thought the error message was too short but I checked before posting it and that was the whole message.  In any event, I've checked using the latest version and I'm not able to reproduce the error (which was easy for me to reproduce before).  thanks
Track Info panel works worse. It can't find any artists for multi-artist tracks:
Confirm now it finds first artist for multi-artist tracks.
Thanks for supporting this! Very convenient and looks much better than I expected!
Even though Auto DJ is shown in the navigator, it is not coming up in shuffle rotation from the player controls.  Is this intended?
its working fine here. The only reason i am aware of would be the skin you are using is a custom bitmap that doesnt have an image for the auto-dj
No, it has an auto dj image.  Maybe it's an issue with the sidebar player?  Here's a GIF: http://imgur.com/kYtDO79
KissCool
Tried to use the Semi-Bold style of the Segoe UI font and I have an issue with columns displaying number (like "Time").
With Regular/Italic/Bold style, everything is well aligned (sems to use the "justified" alignment setting). Eg.: same width for 1:11 and 4:44
With all the new Win 8/8.1/10 styles (Light/Semi-Light/Semi-Bold/Black), numbers are right aligned but don't have the same width.
Rebular vs Semi-Bold (just compare numbers with one or more "1" vs numbers without "1")
i wont be able to help with that as its windows doing the text formating
KissCool
OK.
2 probables bugs (maybe already reported. Sorry if they are):
 - rating a track doesn't update the Album Rating ("store ratings in the music file" unticked, "auto-calculate album rating" ticked). Sometimes Pressing F5 works, but usually, have to restart MB.
 - dunno if it's intended, but we can't expand the right sidebar in Now Playing tab (Theater Mode). Only the header appears (think this one was already reported, not sure)
Unfortunately i made a bad decision to allow the navigator to be placed in the left main panel.
There are some implications with various functionality so i am going to remove support for placing the navigator in that panel ie. it will only be enabled to be docked in the left sidebar.
Anyone who already has the navigator in the left main panel, it will still work but going forward you wont be able to drag the navigator from the left sidebar once its placed there.
