Author Topic: A question about the conversion process of DSD.  (Read 2531 times)
Leroy Bad
When Resample to 96khz is selected in the Audio Player settings, does the conversion of DSD to PCM resample first to 88.2khz and then resample again to 96khz? Or does the conversion resample straight from DSD to 96khz? ???
i would say it does 2 conversions. If i get time i will change that so it goes direct to the resample rate
edit:
no its not possible - the dsd rate needs to be one of: 44100/88200/176400/352800
Last Edit: February 02, 2015, 09:22:47 PM by Steven
Leroy Bad
Thank you for checking.
is it possible to add 176.4 and 352 khz output for DSD in the future?
dtb300
+1
viherbos
That would be a great idea since native support is not available.
Thanks a lot for your great effort with this tool!!
