Author Topic: Can you disable star ratings?  (Read 4016 times)
Super Meat Boy
I don't need the star feature, I want to disable it completely.
Simple enough - just don't use it.
Unless what you're asking for is an option to make it not appear.  In which case you should post your request to the Wishlist section.
You can hide/remove it from pretty much everywhere except the tag editor.
