Author Topic: Remove silence option when burning a disc  (Read 2935 times)
9ido
Dear Steven,
When I listen to a playlist that's intended to be without gaps (using the wonderful remove silence option) I would definitely want the same when I burn a disc! Could an option for this please be implemented? Just a tick box next to the 'Level volume' option would be absolutely fantastic! Or otherwise, as you see it would be best. :)
Cheers!
Looking at the Disc Burner window, I already see the option to have no gap between tracks when burning an audio CD.  The option is directly above the 'level volume' option you referenced.  You need to enable Audio CD for it to work.
9ido
Dear Phred,
That's a different thing. That's about having or not having that -2 seconds countdown pause added in between tracks.
This request is about trimming the actual silences in the tracks themselves, as you can choose in the preferences > player settings.
MusicBee can do this currently when playing, but not when burning. And of course, when I burn something I would want to burn it like I hear it when I play it. :)
Cheers.
Understood.  I guess I misread your request.
