Yeah, I know, another necro post, but I noticed back in 2015 that someone had posted an issue just like mine and there were no responses. I wanted a temporary library to use on a flash drive, I didn't want the library to stick around, but I DID want the files to remain on the flash drive. It was easy to remove all the files *only* from the library, but as far as I could tell there was no way to remove the library itself from MusicBee short of 1) deleting the files on the flash drive, which I didn't want to do, or 2) using the last poster's suggestion of deleting the MusicBee folder, which I did. Though draconian, it did accomplish what I wanted and rebuilding my original library was very quick. What I wanted to know is, is there any other way to remove all traces of a library from MusicBee without deleting files? Thanks.
