Hello All,
I have been happily using MB for some time now, but every once in a while I have problems updating/scanning folder.
I have two separate folders selected to scan. It appears that one scanned into the library, and one into inbox. I have now made sure that new files are added to library, but I may have had this set up wrong before. I thought maybe all I would need to do is drag files from inbox to library, but that did not work. I drag and dropped a full album from inbox to library, but it does not show up in library. When I go to "recently added" the album is displayed, but not in library.
Anyone have an idea what I am doing wrong? I have everything set up in monitored folders, and under rescan for the correct folders.
Thanks!
edit: when I created a new library, and selected the same two folders, it appears everything was added to the library. I did then check my preferences, and it did default to "add new files to inbox", so maybe that was what was confusing me?
