I never actively used the Inbox feature of MusicBee, and just started experimenting with it a little bit to see if I have been missing an important feature I could put to good use.
Currently I am running into the problem that the Inbox doesn't seem to be actualized when files have been edited with 3d party programs.
To explain what I am trying to achieve at the moment:
I have created a monitored folder which I intend to use as an Inbox folder. I have checked the 'continuously monitor' option.
When I see a file in the Inbox that I want to correct, and I use a 3d party program to do that (Tag&Rename), the changes are not picked-up by MB. Not even after a restart.
What can I do so that those edits are reflected in MusicBee? (apart from rescanning my complete library)
