Author Topic: How to move MusicBee (and its libraries) to a new PC?  (Read 7673 times)
klint
Hello
I have to change my PC and I would like to move my entire library to the new PC, by preserving all information.
Unfortunately, the new and old pathes don't match.
Is there a safe way to do that?
Thanks
You can just copy the folder that has your MusicBee library to your new PC, then tell your new installation of MusicBee to use that when creating a new library. If the paths are different, use the "Remap" command as explained here:
http://getmusicbee.com/forum/index.php?topic=14617.0
Given that this question is asked what feels like once a week...
What do I win?
What do I win?
A permanent clipboard so you can paste your response more efficiently.  :)
Or you could just link to the Backup & Restore page on the wiki.  :)
http://musicbee.wikia.com/wiki/Backup_%26_Restore
klint
Thanks a lot for all your helpful answers :)
I promise I searched both the wiki and the forum, but with the wrong keyword combination actually (although quite logical: "move library" :) ), ending up with either too many results in the forum or fewer results in the forum but none applicable (maybe it could help if the wiki entry contained the word "move"??)
Cheers
