Author Topic: Musicbee skins stuck.  (Read 2296 times)
dylstew
I started up musicbee, it said it could not load a bunch of preferences (I pretty much only lost the library itself, so that's okay) and went it to the default skin.
I picked a different skin, but it turned out to be the wrong one. I tried changing it to the real one, and now the program stops responding (no error message, it just doesn't work) when I pick any other skin.
Last Edit: January 05, 2015, 08:41:21 AM by dylstew
you dont explain the background to this - i assume you had some sort of hard disc problem.
It sounds like you need to do a full re-installation
I doubt anyone would be able to help you based on the information you have provided
dylstew
Ah, sorry, The thing is, I don't have a clue either xP.
Guess I'll just have to back up my settings and re install.
Thanks for the response.
