Author Topic: Can musicbee convert 320kbps mp3's to 192 kbps?  (Read 3626 times)
dylstew
I have pretty cheap equipment and hardware, so I can't really hear the difference between 192 and 320 anyways, so I wonder, can musicbee convert 320 kbps to 192?
Pingaware
Yes.
More informatively, right click on the files you want to convert and go to Send To>Format Converter. You'll have to check your profile settings in Preferences>File Converters and make sure that the steps here are followed.
dylstew
Thanks.  I'm using LAME. Do you prehaps know what parameter do I need to type in for a VBR  192 kbps file?
edit: nevermind, I found a reccomended setting details tab here: http://wiki.hydrogenaud.io/index.php?title=LAME
Last Edit: January 04, 2015, 01:58:55 PM by dylstew
