unzip and replace the existing musicbee files:
http://musicbee.niblseed.com/V2_5/MusicBee_Exe_Patched.zipthis is the final planned update for this functionality:
- continuous monitor now detects deleted and renamed files
however the way windows works is when you move a file from one folder to another, its messaged as a create (in the new folder) and then a delete (in the old folder). There isnt a guaranteed way i could figure out how to link the two messages. What that means is if you do that, then you
won't lose the file from your library, but you will lose playcounts, any tag data that is only cached in the musicbee database, and the file would be moved to the Inbox if configured that way in the monitor. The same would happen on startup if you moved the file when MB wasnt running
- renaming the directory or the filename only should work fine
- deleted files are removed from static playlists
- this also fixes a couple of small bugs with yesterday's version for new file detection on startup
- this version also provides more feedback about the changes detected
