Author Topic: Mark as played  (Read 2231 times)
karol2d
As you know the last.fm sync does not work perfectly due to last'fm's quite miserable correcting system. Thanks to it, some of my songs aren't updating the 'last played date' and 'play count', in conclusion it messes up my autoplaylists.
Can we hope to have a possibility to manually mark songs as played (update last played date and playcount) ?
Pingaware
You can update play count for songs individually under the properties tab of the tag editor. However, you can't batch edit or change the last played date at all.
karol2d
Ok, I get it. But is it possible to implement it? Or update last played date directly from iPod or iTunes. It is basically impossible to maintain proper auto-playlist based on last played date, when using iPod for playing music as well.....
