Author Topic: resize album art in Details tab  (Read 3017 times)
Since you seem to be bursting with energy and having fun granting wishes:
In the Artwork tab, album art is nicely resized to give a full view of the album cover, but in the Details tab it is cropped depending on original size.
Unless this is intentional, please have artwork in Details tab also resized to fit the panel.
Tia
If you set it to "Fit to Panel" in "Configure Panel Settings" it will do this, but only horizontally.  Would be nice if it took horizontal & vertical dimensions into account (especially since when it gets cut off vertically, the scroll bar also covers up part of the image horizontally).  The way it's done in the Artwork tab is perfect.
If you mean the Details tab in the right-hand side (mine at least is below the Now Playing List), then +1.
Having the sides of the artwork cut off has been irking me too.
