You have one file, then the playlists are generated based upon the tags.
I have searched for any cohesive explanation for this in the help system again.
Where to put own tags (instead of links in directories of these names) like e.g.:
"Walzer"
'"valse" and "+++"
"milonga" and "++"
"tango" and "++"
"soul"
And then: How to generate or edit a playlist of e.g. all tracks tagged '"valse" and "+++"?
Or a playlist having four tangos, then a "cortina" track, four tangos again, then four valses, again four + four tangos, then four milongas, etc.?
And then - while hearing and testing - I need to replace some tracks by better fitting ones.
And then I need to change the order of some tracks within the group of four tracks.
The topic "How to use "text file to tags" feature" did not help.
The Topic "How to Copy & Paste Only Selected Tags between Multiple Files" did not help either.
Is there any manual besides the help system?
Are there any examples anywhere? I think many DJs need to compose their playlists like this.
Thank you in advance - tomte-da
