Could you add a blank entry to the file converters so we could make our own profiles? For instance I'd like to use iTunesEncode for my iPod since it gives better results for me than Nero. It was made by a guy at Hydrogen Audio forums and it acts like a middle man for sending any audio file to iTunes conversion (since the damn thing doesn't like FLAC).
So basically I'd add one blank profile like: Custom enabled, Codec Name, File Extension, Portable, HQ, Archiving. If you'd rather not do it perhaps I can send you the command line parameters for encoding and you add a hard coded profile like the rest.
The requirements for this encoding is the iTunesEncode.exe plus a running iTunes (encoder is set-up in iTunes).
