Author Topic: Your top 3 requests  (Read 20194 times)
  • MB Version: 3.6.8878 P
Did I make it back from holidays in time to add mine?
1:  This one, personal/universal ratings, as you already said you had an idea for this to work
2:  And this one, show all artwork, as I'd really like a way to display, in the artwork view, all the album art I have linked to a release.
3:  If I can't have this one reconsidered, than list genres would be my third choice.
- Moving from Inbox Respect Auto-Organise
this is included now for the Send to Library command. It will display a popup dialog if the option is enabled and any files have missing tags, but the popup can be disabled
there is a bug in the last version so it wont work in all cases. It is fixed for the next update
dylstew
Mine would be  being able to use something like this mp3tag rateyourmusic script : https://preview.cubbyusercontent.com/pli/RateYourMusic_03.zip/_8df0d6fcf7fb40f7902e8506bf48f7c7
(from the last post in this thread http://forums.mp3tag.de/index.php?showtopic=10178&st=15)
In the auto-tag album thing in Musicbee itself.
i am locking this topic now - any new requests should be created as a separate topic. I will still do a few of the items already requested
http://musicbee.niblseed.com/V2_5/MusicBee_Exe_Patched.zip
unzip and replace the existing files:
I would like to be able to prevent changing ratings for example together with the view "Main Player (Locked Down)" or as a separate option for all views but the inbox. Or as an alternative to be able to undo such changes.
i have included rating changes in the undo function
Actually I have 1 more wish which I asked a long time ago: localizable standard playlist names. It should work like localizable .lngc filenames, but localization strings must be defined in currently used .lng/.lngc file, rather than internally for MB. Something like:
they are in the next translation file. Note that it only works for new users and wont rename existing playlists
#Main.menu.RecAdd#   Recently Added
#Main.menu.RecPlay#   Recently Played
#Main.menu.Top25Pl#   Top 25 Most Played
#Main.menu.TopRated#   Top Rated
