Author Topic: iPod sync skip same name tracks  (Read 1801 times)
Toshio
I use iPod 5G with MB.
Sync select music playlists which have tracks with same name but have differ disc number.
MB sync only one track to iPod, but when I use iTunes and foobar2000 , I can sync that tracks.
Are you using the iPod/iPhone plugin?  If so, you need to post this in the plugin's thread.
If not, you're lucky that you're able to sync with MB at all.  Most iPods don't work with MB.
Toshio
First, I use iPod/iPhone plug-in, but not files copyed, first mentioned.
Next, plug-in invalid , MB sync, same result.
I understand, this move iPod/iPhone plug-in thread.
thank you.
