Author Topic: I want to keep Shuffling off.  (Read 1962 times)
airdoo
Based on my search results I'm in the minority by not wanting to listen to my entire library shuffled. Is there a way to disable the "Play Library Shuffled" function when I double click "Music"?
I'm running MusicBee 2.5.5456.
Top right corner of the window is an icon with two crossed arrows pointing to the right.  Cycle through it (two clicks, probably) until the icon is not 'lit.'  That turns off all shuffling.
airdoo
That gets enabled again when you double click "Music" under "Library". It'd be nice if I could do that without it re-enabling Shuffle and then starting somewhere randomly in my library.
Yes, I can reproduce that.  But I'm not sure if that's the intended behavior or a bug.
