Author Topic: Is there a way to sync only those files off a playlist in a specific format?  (Read 1320 times)
so_la_la
Is there a way to sync only those files off a playlist that are in a specific format and hence need conversion?
I have the other files copied to the sd-card with the WinExplorer.
Music Bee 3; EAC; MP3Tag; Music on Synology NAS 115; Logitech Media Server on RPI 3; RPI 2 with Hifiberry; Poweramp for Android/Lineage
If you're basing the need for conversion on the extension of the filename, you can create an Auto-Playlist where the filename ends with .mp3 (or .flac) or whatever.  That would show only those files in the playlist and you can more them to the card with MB.
