unzip and replace the existing files
http://musicbee.niblseed.com/V2_5/MusicBee_Exe_Patched.zip- rename actions now removes the remaining folder if empty
- MTP device synching now uses a faster API to move files within the device if the device supports that API action. Otherwise MB does the copy/ delete action as now, except the delete action will be much faster
- if you start getting a lot of errors on file naming actions please let me know as it may be the new move API is not working properly
- preview now shows 2 folder levels and the filename (was 1 folder level and filename)
- fixed a few bugs with the GUI
